Kaisersoze
Can't say that I have any experience with this, but i would recommend comparing the extended length of the manual adjuster to the full extended length of the stock automatic adjuster. This will give you a base-line to compare the manual adjustable unit (i.e. how many threads "in" you will have to be before you are engaged a similar amount as the stock unit). Does that make sense?
Completely makes sense. I was just thinking that. Hopefully I didnt damage the guides or anything if i overtightened. Going to try that and pray *gulp*.
EDIT:
Measured the auto tensioner... was 1 3/4". Adjusted manual tensioner to 1 3/4" Let see what happens.
