Hey everyone, thanks for the comments.
The frame sliders are Shogun brand. They were the cheapest I could find (on eBay I think?) and did a hell of a job. The slider itself can rotate around w/o the bolt inside turning (it was this way since I installed them). So fortunately, the spill happened at such slow speeds, and the bike was leaned over already in the turn, that it didn't actually have that far to fall to begin with.
The slider wore down about 1/3 of the way, at an angle.
As far as I know, there is no way to install axle or swingarm sliders on an '07 FZ6. Certainly there are no spots to screw them in on the swingarm like there are on full-on sportbikes. They would have saved some scrapage for sure.
And thanks Mississippi/SovietRobot, that is exactly the place that is damaged. The fairing did crack on that side (all the way through
) but I will have to check that out. Probably, I won't replace any of the fairing to be completely honest, at least I don't feel compelled to do so right away. I will try the rattle can BBQ paint on the case to see what happens, I'm sure it will look crappy if you look closely at it, but at least it won't jump out at you like it does now. Thanks for the eBay tips, I will keep an eye out for it there. I'll probably try out some larger, heavier bar ends to cut down on buzz anyway.
Does anyone have any recommendations of things to consider before getting back on the track with it? I have a track day coming up in April ...
Thanks!
Thanks!
