romlin
I was thinking of fitting an extra set of lights to my fazer. Any done this and if so what did you fit?
had seen this set
Halfords | Ring Compact Cruise-lite
had seen this set
had seen this set
Are you looking to put more light on the road at night, or to make yourself more visible in the day? If the former, the best way to do so is by installing xenon projectors. There are several threads about doing so. It is not cheap or easy, but from what I can gather it practically turns night in to day, without blinding oncoming drivers. If the latter, have you done the dual-headlight (aka bd43) mod to light up the unused low-beam in your right side headlamp? OR, as ana laternative or in addiotn, there are some nifty LED options, like these:
BikeVis Store | BikeVis Bullets
Be aware that the lights at your link seem to be 55 Watts each, total 110 Watts. The FZ6 charging system is probably not capable of handling that much extra load. (That is one advantage of the projector mod, they use less energy than stock, freeing up capacity for other extras, like heated clothing.)
That's sounds awesome mate - I'll keep watching this space.
