chunkygoat
Good luck with that bolt, i had the exact same problem, with the same bolts. On my 08, it looks like they welded the nuts on the other side, maybe to try to prevent you from taking them off.
For whatever reason, I just skipped that step and bent the plastic to slide the old pipe out, and the new one in. I wouldn't suggest it, because you can break the plastic if you bend it too far...but it worked for me.
Good luck.
Good luck.
