Intermittent starting problem
So it was cranking, the starter motor was spinning at normal speed but the engine not starting? Or the starter was not spinning?
in that instance the starter motor wont spin, you'll hear the relay click, but unless the starter motor is in the right position it wont get enough current to spin, hence it is intermittent.
The push start means fuelling, spark, air etc is all ok.
