fazer600spGR
I READ TO YOU ALL WITH ATTENTION, I DO NOT NEVER PASS IN THE OPPOSITE CURRENT OF CIRCULATION WITHOUT PERFECT OPTICAL FIELD!!! yes i ride fast because I believe that if I didn't make it fast, it would be supposed I buy a scooter or harley davidson [OK]? MY LINES THEY IS NOT GOOD BECAUSE I AM IN PUBLIC STREET AND IT SHOULD I HAVE AS LONG AS THE POSSIBLE BETTER OPTICAL FIELD, FEW THOUGHT FRONT YOU JUDGE SOMETHING MAKES VILLAIN. IN THE END I DO NOT WANT TO BECOME GHOSTRIDER NEITHER COPOLLA (sorry for my english ,i use a translate program)OPINION FOR VIDEO
Take a big wad of cotten and tape it against your microphone. It will prevent the wind noise. Turn the volume down to minimum on your microphone if you can.
Good choice in music! At least you got that right.
USE A WIDE ANGLE CONVERSION LENS!!! If you can't attach a wide angle conversion lens to your camera - you need a new camera altogether.
Use original color for your video. The contrast in color will make it look like you're going faster and add more realism. Only use greyscale footage for special conditions, usually involving a story or flashback.
Use more cuts and scene transitions, because a single camera angle can get boring after 5 minutes.
OPINION FOR DRIVING
DO NOT PASS CARS OVER A DOUBLE YELLOW!!!
STAY AWAY FROM THE CENTERLINE OF THE ROAD WHEN GOING UPHILL!!!
SLOW DOWN WHILE CLOSING IN ON A 4-WAY INTERSECTION!!
DON'T PUT TAGS IN YOUR VIDEO THAT IDENTIFY THE COPS!!
---Yes, I am literally screaming this stuff at you from my computer. Damn.
One last thing: if you insist on making more videos then spend at least an entire month planning them. Drive down the road at least 10 times, going the normal speed limit while obeying traffic laws, so that you can plan EXACTLY what you're going to do. It should take a long time to make ONE of these types of videos. You might even need to drive the route IMMEDIATELY before making a recorded run. Even people like "The Ghostrider" had spent nearly 2 months on planning for a single video. Even guys like WAVEX, who've ridden on roads a hundred times, have bailed their bikes on the same turns. It's only a matter of time.
