alkinoos
This is what i did to my fazer.
I did it all myself in my garage without any help from a technician.
I will try to descripe the mod as best as possible.
My english are not that good and maybe i have several problems with some technical terms but i will do my best.
First of all we need to modify the lower triple clamp of the GSXR so it can be fitted to our FZ6 fazer.
In my case i did something very simple and i resolved the problem very easy.
As you can see in the first picture i've unpressured the central axis from the FZ6 lower triple clamp and i've fitted it to the GSXR's lower triple clamp.
With this way you can use the fz6 ball bearing with gsxr's triple clamp.
After this, we have to remove the old fork stoppers (i couldn't find a better description for this, dont laugh!!!) an create new ones.
After all, we dont want the usd to stop every time we turn on the frame.
After this, i've bought renthal's "ultra low bar" with the code 758. It is ideal for this mode and i also bought a pair of steering bar brackets.
These ones are used and i really dont know from what kind of bike came from.
I did some job with the upper triple clamp too.
The Gsxr's triple clamp has the lock at the middle and there is no way to fit and work properly at the fazer's frame.
There is no way to lock the steering bar on the frame if you are not change the position of the locker.
As you can see at the picture i've moved the lock from the center to the left of the upper triple clamp.
The trickiest part was the disk rotors.
I wanted to keep my original 5 spoke wheel but the space between the disc rotors where smaller than the gsxr's.
That means that if you want to use the radial brake calipers you also need the suzuki's front 3 spoke wheel or you can make spacers (3mm its side) and keep the fazer's wheel.
That was exactly what i did. I've created spacers to a cnc machine, i kept my wheel and my disc rotors.
All this thing with the disc rotors ignites an other problem concerning the brake calipers.
The suzuki has 310mm disc rotors and the fz6 has 298 mm disc rotors.
The brake calipers where 5,5 mm higher than i've expected.
I have to admit that i didn't see this coming!
So, i took out the calipers and i had them lowered 5.5 mm.
At the same picture you can see the fazer's wheel fitted at the suzuki's forks.
I did it using spacers and pressured rings but unfurtunate i dont hae any pictures available. Next time when i will have my front wheel of the bike i will update the post with pictures.
Here you can see the radial brake pump from Nissin and a couple of pictures from the lock.
In this picture you can see the usd fitted in foul working condition.
You can notice the axis bolt from the suzuki fitted to the fazer's axis.
If you have any further guestions, please, be free to ask.
