ReapeR
ok i tried to keep it as simple as possible and ill get some pics up to show wut i had to do. where the fairing bolts to the r6 upper i had to trim a lil off so it would fit tight to my upper. then drilled two holes in my upper to bolt it on.the mid pieces wrap almost all the way so youll have to cut it off where depends on what you want it to look like. there are some pop in mounts on the plastic i just cut all those off so it would be close to the engine and frame. where the two pieces go together and bolt to the frame i used a clamp. i wrapped it around the frame and put the bolt in make sure the clamp tightens or you could have probs as for the bottom i had a belly pan on it and i use the brackets that came with it to secure the bottom. but i wouldnt be hard to make a mount. just put the plastic up there ( secure) with straps or sumthing along that line and find where to put a mount, make it and make sure itll work before you take the plastic off. if you have any questions just ask and ill give all the advice i can. good luck.:thumbup:
