S107
RE: 2006 FZ6 33,500mi Recent oil change. Added 520 kit about 1500 miles ago. -1 +2 moderate freeway time and light wheelies.
So I start the bike up this morning. I let it warm up everything is fine. Lift kickstand, Shift down (from N) with clutch pulled in- Everythings still ok. Now as Im letting clutch out, the bike jumps foward and cuts off. This happened about 3 times in a row before I started checking things out. Clutch cable is good. Friction point is set close to the grip as usual. But this has been set like this forever and has never been a problem.
After moving the friction point of the clutch back out from grip and checking kickstand cables everything appeared fine. I cycled through 1st about 4 times before heading home. I was at work with limited tools. What could it be? I was worried about it being a kickstand wire malfunction.
2 Questions:
1.)What do you think caused the bike to cut off?
2.)What would happen if it is the kickstand malfunction and i was on the freeway? Would the wheels lock up or will there just be a loss of power?
Thanks Guys!
-Mike S.
2 Questions:
Thanks Guys!
-Mike S.
