Question FZ6N random plug
Bates
Guernsey, Channel Islands
Hi All,
Rear left side I have the connections for the rear brake and indicators. There is plug that isn’t connected to anything. It has 2 greys and 2 black cables in the plug.
Does anyone know what it is for?
The bike is a FZ6N 2010
I'm looking at the schematic and the only only grey wire I see is to the Crankshaft Position Sensor (CPS)
The FZ6 only uses 2 square 4-pin connectors:
Connector (6) Main Fuse - red, red, blue/white, red/white
Connector (C) Sub-Wire Harness - red/blue, red/black, blue, green/black
There are T shaped 4-pins and a lot of 6-pins. I think you may have an aftermarket device. Where to the wires lead to?
Hi, I haven’t looked that far yet. Was waiting to see if anyone knew off hand. I’ll have a dive in tomorrow. Cheers
Okay I had a quick look and they just go to a connector under the tank. I buzzed them out and The connector under the tank had a joint at the top so they are all connected together.
