Forthelols
Hi! I need help with my fz6, it wasn't started for 3 or 4 months and suddenly didn't start and showed a error code 46, I did some research and found out it was a not normal voltage error for the FI system. The bike has a brand new battery so i ruled that out, when started it primes and cranks but doesn't run, i know the spark plugs work and the individual fuel injectors work, so i checked the nominal voltage(positive lead to the red wire with blue stripe, and the negative to the battery while the ignition is on) and it vas only 0,043V and i have read and been told that the nominal voltage needs to be 12v and the ecu controls the ground connection. Right now i am really stuck and would appreciate all the help i could get. oh and i have checked all the fuses and relay pins all where fine.
