urbanj
I had the FZ1 bar pics on another thread but I took some crappy Blackberry pics of my top speed indicator and I figured I would put together a bunch of pics for when people search. The install is straight forward. All you have to do is either grind/file/cut the tab on the throttle assembly or drill a hole for it.
If you choose to drill the hole make sure when you measure to take into account the bar end. When you remove it you will see that it is stepped and part of it is covered by the throttle tube. If you just measure the throttle tube and then measure back from the bar end you will have an uneven gap from the grip to the bar end. I drilled the hole inline with the stock location. I rotated the bar all the way down to give the controls 1mm clearance from the tank lock to lock.
The TSI is the little red button on the left.
