outasight20
Hey all,
I know there are a million threads similar to this one and I already read through a lot of them. I am simply looking for some clarification.
My only gripe with the FZ6 is the loose unsettled feeling I get when I hit bumps in turns and the front end dive under hard braking. Does changing just the front fork springs and oil fix this problem?
Racetech sells their gold emulator kit, does anyone do this when they change their springs and oil? What if any difference does it make?
I replaced my fork seals and fork oil with 10wt less than 6 months ago. I would prefer to not remove the seals to change the springs. Do the seals have to be removed to change the springs? If I remember correctly, I could remove the springs by just removing the fork cap.
Can anyone who has done the Racetech spring upgrade share their experience with both the process and improvement to handling and braking?
I weigh 180, about 205-210 with gear. Racetech recommends .90 kg/mm springs, however I've read most people around my weight go with the .95 kg/mm.
Finally, when changing to Racetech springs, is the stock rear shock still adequate, or does the front upgrade highlight the weakness in the rear? I'm not looking to race my bike, I just want more confidence in the corners and a more stable feeling over bumpy roads.
