Front Fork Damper
wndsrfr48
Jacksonville Beach Fl
Renewing the fork seals on an '07 FZ6 along with installing Racetech springs. Having a problem getting the damper out. Tech Manual calls for a special tool to hold the damper while removing the bottom damper bolt. Anyone come up with a "shade tree" way to hold the damper? I have air but the damper still spins using an impact wrench.
shove a wooden broom handle in there and hold it firmly, the bolt is threadlocked in, once you crack the seal it should come undone easily
Didn't have a broom handle so I used a piece of 1/2" quarter round molding that had a 45* angle already cut. Tapped that puppy in the damper and used an impact wrench, bolt zipped right out.
Many thanks
no worries :)
i would recommend the a proper seal driver though, i had problems getting mine back in and ended up taking it to a mechanic to assemble :(
Re: Front Fork Damper revisited, installing seals
Found that a section of 1.5 in thinwall PVC pipe works well as a bushing installer. then adding a coupler to the 1.5 in PVC pipe makes a good seal installer. The coupler will need to be tapered a bit to fit down in the fork leg. 15 minutes on a grinder does it for the PVC coupler.
Bottom line is I was able to do the whole job with no special tools. Just the tapered broom handle mentioned in Greg's response and a length of 1.5 in PVC thinwall pipe with a coupler. Piece O' cake!
I used the FRSP S3732095 springs, but to be honest, I did not know the spring calculator was on the Racetech website. probably would have gone a step heavier had I known about the calculator.
Can't give any feedback yet as I am still rehabbing the bike and installing other mods. Leo Vince exhaust up next
A trick I've found is to cut a single slice up the side of the PVC. It allows it to expand to sizes greater than it is and even contract to smaller sizes if you cut out a bigger slice!
Good Job and let us know how it goes. What oil are you putting back in (weight) and did you opt for the emulators???
i think pvc pipe must be a different size over here, as when i tried it it was too small. Cutting a slice down the side just resulted in bits of plastic goign everywhere, hence i ended up taking it to a mechanics (plus i just wanted it fixed :D)
