Plokon
So I noticed this problem today, my front brake lever isn't 'resetting' itself. There is a push rod in a metal boot that seems like it should be providing more spring force than it is to push the brake lever all the way out. It isn't a problem with actually braking, but it is making my brake light stay on all the time because the lever won't open up all the way to disengage the light switch. My current fix was to put a spring from a pen over the little push rod to push the brake lever back out, but I'd really rather get it fixed properly.
I found a 'master cylinder kit' that has the parts I think I'll need to fix this
Yamaha 5VS-W0041-00-00 - Cylinder Kit, Master : Ron Ayers
My questions: Will that kit actually fix the problem, and will I be able to put those parts in without having to drain my brake fluid? I'm in college right now, so I don't have anywhere to work on my bike besides the parking lot, and I'd really rather not drain the brake fluid because I have no experience changing it.
Thanks
Thanks
