Scott,
Not likely. There is divider so to speak likely to control oil slosh. The internal structure of thr pan has several dividers each has a narrow slit in them connecting the sections to lowest part of the sump.
Look here you can sorta make out that float sensor is a good bit higher than the drain hole.
