Have not messed with carbs in a long time. My friend has a Shadow 750. It sat for a while and would not start. It dumped gas out of the carb when trying to turn it over. Took the fuel bowl section off the bottom and cleaned the injector mechanism, the bowl and just sort of a general cleaning. Replaced the needle that sits on the float. After putting it back together, it would start and idle with no problem and no fuel leaks. As soon as you even tried to crack the throttle a little bit, it died. Someone said it was bad gas in the tank after sitting for too long. We drained the tank and fuel bowl in the carb - then filled with fresh gas. Had the exact same problem. After researching and thinking about it, we took the fuel bowl back off and removed the slow and main jets. The slow jet was completely clogged. Could not see through the hole at all. After thoroughly cleaning both jets and reassembling, the bike runs great!! Felt good to finally figure out the problem. :wav:
