Fault Code: 12
Diagnostic Code: --
Symptom: No normal signals are received from the crankshaft position sensor.
Diagnostic Code: 03
Symptom: Intake air pressure sensor-open or short circuit detected.
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Diagnostic Code: 08
Symptom: The motorcycle has overturned.
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal.
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Diagnostic Code: --
Open or short circuit in wiring harness.
Defective crankshaft position sensor.
Malfunction in pickup rotor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 13Defective crankshaft position sensor.
Malfunction in ECU.
Diagnostic Code: 03
Open or short circuit in wiring sub lead.
Defective intake air pressure sensor.
Malfunction in ECU.
Fault Code: 14Open or short circuit in wiring harness.
Malfunction in ECU.
Diagnostic Code: 03
detected hose
clogged hose
Intake air pressure sensor hose is detached, clogged,
kinked, or pinched.
Malfunction in ECU.
Fault Code: 15clogged hose
kinked, or pinched.
Malfunction in ECU.
Diagnostic Code: 01
Defective throttle position sensor.
Malfunction in ECU.
Improperly installed throttle position sensor.
Fault Code: 16Open or short circuit in wiring harness.
Malfunction in ECU.
Diagnostic Code: 01
Stuck throttle position sensor.
Malfunction in ECU. 01
Fault Code: 19Malfunction in ECU. 01
Diagnostic Code: 20
Open circuit in wiring harness (ECU coupler).
Malfunction in ECU.
Fault Code: 21Malfunction in ECU.
Diagnostic Code: 06
Defective coolant temperature sensor.
Malfunction in ECU.
Fault Code: 22Defective coolant temperature sensor.
Malfunction in ECU.
Diagnostic Code: 05
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30Defective intake temperature sensor.
Malfunction in ECU.
Diagnostic Code: 08
Overturned.
Malfunction in ECU.
Fault Code: 33Overturned.
Malfunction in ECU.
Diagnostic Code: 30
Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34Malfunction in ignition coil.
Malfunction in ECU.
Diagnostic Code: 31
Malfunction in ECU.
Fault Code: 41Malfunction in ignition coil.
Malfunction in ECU.
Diagnostic Code: 08
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42Defective lean angle cut-off switch.
Malfunction in ECU.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43Defective speed sensor.
Malfunction in ECU.
Diagnostic Code: 09
Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44Malfunction in ECU.
Diagnostic Code: 60
Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Malfunction in "CHARGING SYSTEM".
Fault code: 50Malfunction in "CHARGING SYSTEM".
Diagnostic Code: --
Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1 properly written on or read from the internal memory.)
Diagnostic Code: --
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2Malfunction in meter.
Malfunction in ECU.
Diagnostic Code: --
Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3Malfunction in meter.
Malfunction in ECU.
Diagnostic Code: --
Malfunction in ECU.
Fault code: Er-4Malfunction in meter.
Malfunction in ECU.
Diagnostic Code: --
Malfunction in ECU.
Malfunction in ECU.
