Roboco
I left the key in the ignition all day and the battery is dead. Can I jump start the battery with a car or are they different amps? Any suggestions? I doubt it will pop start.
Um, if the battery is totally flat, how is the fuel pump going to run? The fuel injectors are electric too. I did this (left key on) and if the fuel pump does not run, push start will not work. This is the one advantage of carbs. I hooked up my (bike) battery to a car battery (car off) and let it sit for 10 minutes, this gave the battery enough juice to run the fuel pump and build up some fuel pressure. Bike popped right off(after a good push).
