astrovan2487
I've been having the same issue with my bike flashing a code 46 since some time last year. I installed a new battery last year and still have the same issue. It seems like it's not as bad, the engine light will only come on once or twice for a few seconds then not show up again. Last year it would come on after riding a good 20 minutes then would stay on until I came to a stop, would go off then the light would come right back on after going above about 4000rpms. The new battery load tested at 10.2 vdc, charging system tested at 14.0 vdc. I did a leakage test and found no problems. The stator windings have no continuity to ground but the resistance is a little out of spec. My meter is reading .4, .4, and .5 ohms between the three stator wires and the spec. is supposed to be between .22 and .34 ohms. Does this mean I need a new stator or could it just be my meter?
