Ssky0078
I hate it when the lube dries up and STICKS to IT!![]()
So wrong, in so many ways:rockon:
+1 on this big time^^^^
To not /service/lubricate a cable is ridiculous...
As Randy noted, its in the manual as a scheduled service...
I hope you don't believe everything you read on the internet...
TO ALL: Sorry for posting the results of some quick research on the Innertube, which led to some false conclusions. I went a good bit further in my subsequent research, and found - via DuPont, the original discoverer and producer of Teflon - that Teflon isn't affected whatsoever by oils and lubricants. In fact, it can only be dissolved by some very esoteric/rare chemicals, and/or adversely affected by some pretty high temperatures.
So nothing we typically use to lube the cables should adversely affect the Teflon lining of my clutch cable.
And I appreciate the consensus opinion that my clutch cable's Teflon lining is probably "stuck" to the outer jacket. I'll be able to confirm that right after the holiday, when I'll be replacing the existing clutch cable. Thanks for all the good advice.
- - - Jim
Most problems can be solved with a suitable application of throttle.
If I were you I'd blow through a whole can of lube just to see if you can get the gunk out. When I was servicing my bike, my friend borrowed the cable clamp and lube. At first his was all gunked up, then it finally busted loose and all this crud came out of the bottom of the cable. This was on a BMW g650GS
