Mr.Spoofy
I just got my FZ6 back from it’s first servicing and the clutch lever is now almost out of reach. Can I call the dealer and have this readjusted or is this clutch setting it? It does shift a little better now.
I would like to move the lever in closer to the handlebar for easier reach and comfort.
i may be incorrect, but for cheaper $ than the pazzo's can you use another brake lever and mount it upsidedown on the clutch perch? My buddies Tuono has adjustable brake and clutch levers and they look identical on both sides...
Probably wouldn't work, but it would be cheap and sweet if it did.
It seems odd that the clutch lever would actually change in distance from the bar; that distance should be fixed. Did they just reduce the amount of free play? That is, as mentioned, easily adjustable at the base of the lever.
Longer shot - has the perch been rotated downwards? That would it harder to reach, making it seem farther away.
They did take the free play out, now the clutch engages when the lever is just about all the way out. I stoped back by the dealer and they said this is the correct setting for the clutch. Before the servicing it had alot of play in it. I'll check the perch too and see if that's it. And it may just be someting I'll have to get more time on to get a feel for it.
