F
formula154
I have been reading about changing out gears, going from 16 to 15 in the front. It looks like all you need are basic wrenchs to do the job. A few questions, after taking the nut off which holds the gear on, how hard is it to get the gear off? Do you need a gear puller or some kind of tool to pull it off with? The other question is how do you know what 15 tooth gear will fit the front of the FZ6. Third does just changing out the front give a noticeable change in low speed acceleration? How much trouble and expense is it to fix the speedometer to read correctly after the change? Thanks.
