Jonno271
On Friday I picked up my nice shiney new Yamaha 46 litre colour matched top box and fitted it to the bike. Nice piece of kit, the mounting plate is far neater than other after market items I've seen...
Straight away though I noticed how far it hung over the tail light. If a truck got a bit close behind there's no way he'd see my brake light come on. Now Yamaha do a brake light fitting kit for the box but the price is rediculous so I thought I'd have a go at fitting one myself...
I picked up 6 high intensity LED's and wired two groups of three in parallel with a 100ohm resistor in line to each to achieve the necessary 3.5v across each LED. Drilled the back plate for the built in reflector and mounted the LED's in their little holders and then put 12v across them to try it out. Hey presto, one high level brake light in my top box costing about £10!...
So far so good, well that's where my luck ran out! I then had to wire the whole lot into the bike...
I removed the tail light bulb holder and tested each wire with my volt meter, deducing that there's a black earth (obv), blue constant 14v for the driving light and a third yellow wire supplying voltage to the brake filament. This reads 8v without the brakes on and 13.5 with them applied (engine running)...
I figured tapping in to the brake light wire and the earth should do the trick. 8v isn't enough to light the LED's but the full 13.5v is. This is where my problem started...
I snipped the black and yellow wires and soldered in my plug lead. This would allow me disconnect the top box electrically. I decided on a quick test to make sure everything was still working at this point. Unfortunately, it was not! The tail light lit up fine but when I applied the brake, it did not get brighter. It was clear the second filament wasn't illuminating...
OK, so let's remove my lead and put things back to standard. Done. Still no brake light, only the driving light. Obviously I tried a new bulb and then put the volt meter across the bulb holder. It still shows 8v on the yellow but no longer goes up to 13.5v with the brakes applied...
Out comes the manual. Checked all fuses, there's only one for the tail light as a whole and checked the continuity of all the wires to the tail unit, nothing wrong there...
And that's where I'm at! Having done a lot of head scratching I can't figure it out. Unfortunately there's no wiring diagram in my manual so I can't really investigate any further. I can only guess that there's another component in the circuit, maybe a relay, that's blown...
I wonder if anyone here has had a similar problem or if anyone knows the wiring a little more in depth and (excuse the pun!) may be able to spread some more light on the matter? Any input would be greatly appreciated, otherwise it's off to the shop the bike goes to get fixed at further expense!
Thanks for reading guys, hope some one can help!
Cheers,
Jon
Cheers,
Jon
