chronostorm
Hey guys,
My 2007 FZ6 was knocked over not too long ago by someone backing into my driveway
It tipped over on the left side. Luckily, I had frame sliders installed, but there was still some damage If you guys could help me out, I would really appreciate it!
First, my left front turn signal got all messed up. The part of the front cowl that the turn signal mount is mounted to broke. I've glued it back, but it doesn't seem to hold too well. Is there an alternative to using those mounting points? Perhaps a turn signal that doesn't mount from there?
Second, my left footpeg (not passenger) was cracked kind of hard. I'm trying to remove the shifter pedal so I can remove the footpeg, but I don't have the right allen wrench. Can anyone tell me what size allen wrench it uses? Somehow, the FZ6 toolkit I keep under my seat doesn't have the right size
Finally, the left passenger footpeg mount is bent. I believe the part that's actually bent is a thin part of the subframe. Is it possible to bend the frame back a bit? It won't be much, and if I remember right, the subframe is not made of aluminum, so it should be possible to bend without damaging it a lot.
Sorry for the wall of text, and thanks for the help! Also, sorry if something shows up during searches. I tried looking, but I didn't see anything while sorting through all the results
