jackay
Re: Beam shutters
Over in the US, you would need the light to be higher on the right hand side. If you flip the shutters around, it will mean that you're projecting the light onto incoming traffic. Probably not desirable and may blind the incoming traffic.
On the other hand...was it easy to take the projector apart? I'm planning to get mine and change the shutters around, you reckon this is can be easily done?
I had one of my projectors apart the other day, investigating how Astennu got some extra wire length. I was not able to comfortably re-route my wires internally without straining them, so I left them as is, but now have some questions about the beam shutters.
Specifically, I notice that both lights have the high-side of the beam shutter on the right side of the light. (The right side when looking from sitting on the bike with the lights mounted.) I realize that these shutters (basically a flat, thin piece of brass with the right side higher than the left) control the beam cutoff, but I'm not sure if I understand how they should be oriented on a motorcycle.
I was thinking that in the USA you'd want the higher side of the shutter to be on the left side of the headlight, to keep additional light from the lane of opposing traffic. Is there another reason for the higher side to be on the right, or does it not even matter? Or should one be on the left and the other on the right? I could probably swap them somehow....
