ChanceCoats123
As one could figure out from the title, I'm looking for some advice from other riders with the R6 fork conversion. I had them dialed in nicely last season, but I've since taken ~ 10 lbs from the front of the bike with my naked conversion. I noticed a borderline tank slapper yesterday under hard acceleration over some bumps (with a minor lean angle) and I'd like to get the nose more planted.
Unfortunately, I don't have anyone else to help me measure static sag so I'm going to try my best to do that today and get it within spec (around 25mm on the front/rear)
I'm 6' tall and I weight 180 lbs, so more like 190-195 with gear on.
If you guys don't mind, I'd love to see some height and weight numbers as well as the preload, rebound and compression damping settings you've currently set on your R6 forks so I can compare and see perhaps a baseline I should aim for before I ride and tweak.
Many thanks in advance!
