All four turn indicators not working...
Mdubs86
San Luis Obispo
Hey everyone, I have recently acquired a 2005 FZ6 and it is great. The only problem it had was a cracked front upper from falling over in garage. I just repaired it this weekend and hooked everything back up but now none of my turn signals will work. My guess would be a fuse but I am not sure. Thanks for any help.
Boneman
Instructor
Victoria, BC
www.bonemanfz6.com
Yeah I would check fuse first.
Did you only fiddle withthe front signals and now none of the signals (front and back) are not working? If so it sounds like a blown fuse or possible a flasher relay.
Mdubs86
San Luis Obispo
All I did was unplug the front turn signals when removing the front upper. I have never touched the rears. Where would the relay be located?
S
sportrider
someone will correct me if I'm wrong but I think is located in the left side pod.
stalocjp
Minnesota
You're right sportrider. I had the same thing happen to my recently acquired 05. The relay is in the left side pod. There is a snap on connector that most likely fell off when your bike fell over. Unfortunately for me, that wasn't the issue with my bike and I had to run a new circuit from the fuse. If you check the connector and that's not it. I did post the process I used to find my problem on another thread - here's the link:
http://www.600riders.com/forum/fz6-technical/682-turn-signalss-hazards-dont-work.html
Dannyfz6
Croydon
Hi, I have just fitted a tail tidy with led indicators and number plate light. When I wired up the light it worked but after a few minutes its stopped all together but as well all four indicators have stopped and so have my side lights. It looks like its a flasher module???? Has anyone had this before???? Thanks
YZF73
West Sussex, UK
May be worth starting up a new thread in the electrical forum if you can't find discussion of the same fault using the search function. Should help get the attention of those in the know. :thumbup:
Yamahaboyz
412fz6
Decepticon
Pittsburgh, PA
DannyFZ6, I had a similar thing happen to me and I found that it was my Tail fuze. The plate lights were wired backwards and it blew the fuze repeatedly. I went through about 15 fuzes before I figured it out. I refused to believe I wired it wrong. silly me. The weird think was that I thought the all the lights were working for a few weeks then all of a sudden they went out. The tail fuze will impact all turn signals the tail light and the plate light. The turn signal lights on your meter may not work either.
why_not_Zoidberg?
Pennsylvania
Also, there is a second fuse holder beside the main one (right side pod). Took me a bit of screwing around to realize that was the one that needed changed. I can't remember if that was for my headlight issue or my indicators though...can't hurt to check them out though.
Re: Re: All four turn indicators not working...
Yes. Same fuse for flasher and running light/tail circuit. Check you wiring because fuses don't wear out.:p
Sent from Moto's Droid using Tapatalk 2
