madmanmaigret
Mad like crazy not angry
Ok, so this story starts with I have a leak in my front tire (have you ever ridden with a low front tire? Scary as all heck
) and I wanted to remove it so I could dunk it in some water to find the leak. I visually searched for the leak and found nothing. Also if there is a problem (like the air keeps coming out) I will have to remove it anyway to bring it to the tire shop and get it replaced. So I put the bike on the center stand and got out the manual. I removed the calipers and the pinch bolt no problem. Then the manual just says to loosen the axle. So I look in the tool kit and see this worthless piece of metal to remove the axle. Well if I didn't break the thing I wouldn't be here typing this now. So after I break it, I drill a hole in it and put a screwdriver through it and try to turn it....... no dice. So now my question is..... is this thing counter threaded or did the assembler put it in really tight? Where can I get a real tool that will make this much easier? I tried some searching but had no luck so far. Am I just going about this all the wrong way(ie; does the axle just slide out?)?
HELP!!!!!! Its 90f outside, sunny, beach is calling my name and........ no bike!!!!!!!
