I'll reveal my FE secret go to a place where you can buy sheet metal.
here's the tools you will need. (most people probley have all of them already)
jig saw
drill
ruler
soap stone or crayon
optional welder
I made mine out of 1/16 inch sheet metal you'll need a piece 8.5" X 6"
here is the pattern that you would cut out
if you add tabs for the stock turn signals it's quite a bit more work.
once you've cut out the pattern you'll drill the holes where marked. you'll need a vise to bend the metal into shape, but it's not necessary if you don't have one you can use a cresent wrench to make your bends. you'll need to bend the two ears in a 90 degree angle up so the notch is at the left side of the FE. then test fit the FE on your bike. from there you'll see where you need to bend the plate so it fits properly. once that line up you'll need to make tabs for your license plate bracket off the stock fender. the license plate light can be used also with a little more cutting on the bracket. if your interested in making this, I can post up detailed instructions
if you already have the tools you can buy the metal for under $10.00, with a few hours of your time you can make one up.
