grahammarsden
Active Member
Have you checked the vacuum take off hoses for breaks or splits where they come out of the front of the cylinders?What happens when the bypass screw reaches the end if it's thread? I tried to check my TB vaccums, cylinders 1 and 4 are on spec (gauge's needle slightly fluctuating at about -220 mmHg) while 2 and 3 are about -185. I tried adjusting no2 but the screw reached its end (clockwise) so i could not match with the reference cylinder. Also turning the screw for no3 did not seem to make any difference. I read that it's important to match all four readings but should I alter the reference setting of cylinder 1? The service manual does not recommend it if i got it right. Never done this myself before so I wonder.
There's a short metal tube that the hoses connect to, but it's thin, as are the hoses, and they can get a lot of strain and movement which causes the tube to wear a hole in them.
