Question Stretched Timing Chain Or CCT Issue
vanness
Cambodia
Hello, during my valve clearance check I've noticed that I was having a hard time lining up all 3 gears, while both cam gears are lined up crank gear doesn't. Is it caused by stretched chain or the CCT gives out (or something else). Note that the bike has no rattling noise, jerky throttle response at low speed and it has 80K KM on the clock. I never work on an engine before, advices are appreciated, thank you.
Plus 1 ^^^
-Start with the crank mark on TDC / block mark.
-Get the chain taught to the exhaust cam-(Both marks should line up to the block / head).
-Now, get the chain taught to the intake cam (again marks should line up).
-Take out chain slack with the CCT on the rear run...
-Done...
You really have to inspect them for wear. If noticeably worn, they need replacement.
With 50,000 miles on the clock, and your replacing the chain anyways, I'd do the guides as well.
Your pretty deep into it at this point.
I wouldn't want to come back in say 10,000 miles for guide replacements.
