Hunter453+
Hello,
I have a 2008 FZ6. When I bought it, it had been sitting for a little and needed to be bump started every other time. I replaced the battery (with a lithium-ion battery) but dropped the fuel tank and broke off the fuel line connector. I bought a new housing and replaced that. I also soldered the fuel level sensor wires (as they became disconnected from the connector in the fuel pump) but when I go to start the bike, it will crank but it will not start. I can feel the fuel pump priming when I flip the killswitch. I also replaced the coil packs and have determined that I am getting spark. I put the bike in diagnostic mode and the fuel injectors are spraying fuel when the bike cranks. I have tried spraying starter fluid in the airbox (with the air filter removed) while cranking but the bike will still not start. I have also tried starting while connecting a 12V 35-T car battery with jumper cables as well as bump starting and it still will not start.
