I took it out for a ride last night and it went splendid for the first half. I arrived at a park after an hour of riding. I shut it down and sat for probably 20mins. When I went to crank, it had a lack of power. The light was flickering, the starter was attempting but no luck. I ended up push starting it and got it running. It was sputtering on and off though, with a loss of electronics. The dash would shut down and come back on. I attempted to get it back home asap. I keep RPMs up and it stayed alive at a stop sign. On the road, it continued to turn on and off quickly and would worsen at higher RPMs. If I keep it around 2000-3000 it would almost stop sputtering. After passing many traffic lights, I, unfortunately, got one that turned red. The bike died and I pushed it to the side. I attempted push starting it. 2 fellow bikers stopped to help and attempted to jump it. It started at first, but then continued the sputtering and seemed to die more easily. I gave in after 30 mins and called a toe truck(we also double check battery terminals to make sure they were well connected). I am going to get the battery load tested tonight. My concern is that it isn't the battery, because if it was able to start wouldn't the stator be able to keep it alive? Adding on to that, wouldn't higher rpm's help as well? I may need to make a new thread for this!
