pmmcanon
Thanks Scott, following your advice a Carbtune Pro 4 is arriving soon
Pretty sure is a balancing/adjusting issue, the idle circuit is very simple: just a cylinder with some shapes that match the body of the Tb sync module, it can only act over air (allowing more or less flow) and surely is highly affected by a misbalanced screws as all the inner shapes are connected. Playing this morning with the tb screws I've reached a "compromise" point where there is some stall when cold and practically nothing when warm. Keep you informed when sinchro is done.
Only 1 point to be sure: Assuming all the screws are wrong, I should primary adjust a certain value in cylinder 1 and then synchronize the rest... As far as I remenber the vacuum ref should be 21 HG/cm2?
KR
KR
