Alkali Fatahu
For sometime now I have been having a tough time starting my bike. If I push the starter button, the engine cranks but will not start. The fuel pump primes normally upon turning the ignition key on and no fault code is displayed.
I initially suspect the fuel pump, injectors and spark plugs. I took the pump out and tested it and it proved okay. I examined the pump housing and there was nothing to show it was clogged.
I changed the spark plugs and also cleaned the injectors and fuel line thoroughly. The still cranks but won't start.
One thing that preceded this was ticking noise. The bike did make ticking any time it was started. This noise lasted a few days after which the won't start. Please, I need help.
