thanks for all answers. I asked directly denso via email:
Subject: * * * *Correct spark plug selection and gapping
Hello, I'm a 2005 Yamaha FZ6 Fazer owner and I want to switch spark plugs from NGK to DENSO iridium.
DENSO's website suggests IU27A to me and that plug's gap is 0.9 mm but Yamaha owner manual says 0.7 mm for CR9EK. I'm a bit confused, should I re-gap the IU27A plugs?
Also, is IU27 applicable for my ride? thank you.
Dear mr Akman,
Thank you for contacting us.
The spark plug gap recommended by the OEM (by Yamaha in this case) is based on the ignition coil voltage (smaller gap is lower required voltage) and the ignitability (ability to ignite the air-fuel mix, bigger gap is more space for the flame to grow).
The centre electrode of the Iridium Power plug is much smaller than the standard Nickel plug (Ø 0.4 mm vs. 2.5 mm).
A smaller electrode means more concentrated electric field, which means a lower required voltage.
The Iridium Power spark plug will have a similar required voltage as the original Nickel plug, but Iridium Power will give better spark.
So you do not need to modify the gap.
If you do modify the gap, there is a risk of damaging the electrodes.
The IU27A is the correct Iridium Power spark plug for your motorcycle.
One of our colleagues uses them in his FZ6 Fazer, and he is very happy about them.
regards,
Wouter Knol
Application Engineer
