When i touch the test light from the battery ground to ANY injector wire the bike will stay running and rev up like normal. So I am assuming that since I am grounding the injector leads, that I have a bad ground.
Just hooked up test like to the battery positive and touched the two ECU ground wires and the bulb would light up. I assume that means a good ground?
One would like to assume that. Lets compare test methods.
A hand held meter testing voltage at the end of wire draws literally NO current. You could have a wire with 50 strands and 47 of the strands broken and your voltage as seen by a meter would appear good!
Lets say we use test lamp at that same point. An incandescent bulb draws current. Id guess just a couple watts. It is much more current than our metter takes but it still may not tell us our wires are broken just becuase it lights.
So, when faced with checking the integrity of a wire we need to load the wire to be tested such that it imposes about the same load as the device it is supposed to operate. Here we can improvise and use a bigger light bulb. One that draws more current. Like a brake light bulb. Or for a short test a 55watt headlight bulb.
If our fuel pump ground to battery POS terminal can power an H1 bulb for second, its very likely it can power the fuel pump.
So you get creative and find ways to isolate sections and test them.
That said, usually damaged wires will have increased resistance that can be measured with an Ohm meter on its lowest setting, but not always. The problem is the difference measured without a load is so small it goes un Noticed.
However as an example; measure from Batt NEG to 3 different ground points and lets say we read 0.3 ohms.
Then we measure our suspect lead wire and it measures 2.3 ohms.... that is a hint one would want to follow and do the load test as it is not like the others!!!
Or measure voltage drop when the wire is under load. A wire sized properly should not show much if any loss when loaded.
An example here is the battery as source reads 12.9 v but we measure the voltage from our battery to our functioning headlight and read 11.3 volts. That means we have loss and resistance. Time to inspect that run of wires, switches, relays along the way for a bad connection...
Does that mostly make sense?
