jacobyjo
I Sheard of my windshield bolts, 2009 ZF6 - how do I get to the inside grommets to replace. My bike feel onto a shelf and the windshield came flying off and the bolts are sheared off. How do I remove and replace those bolts?
The faired version uses a rubber grommet with brass threads.
Assuming this is the same and the plastic bolts were used you have a couple options.
1) using a drill bit smaller than thread shank, use an electric drill and with luck, the bit bites the plastic bolt and spins on though freeing itself from the grommet.
2) use some flush cut side cutters and cut the lip of the grommet off. Push it through to the inside.
Buy new grommets and bolts...
The new grommets push in from the outside and expand into place with the bolt.
Items #2 & 3
2008 FZ6 (BLACK METALLIC X) (CA ED.) - FZS6XBC Yamaha Motorcycle COWLING 1 Diagram and Parts
Six of them, use a small drill bit. The goal is not drill through the sheared plastic but for the BIT to catch and simply spin it out quickly before the rubber spins in the frame.
Why shoot down things that work!?
