Beerdrinker
2^57885161-1
Dear bikers, I need your help!
I disassemble the front fairing and remount it but now the parking lamps wont work!
I connect everything correctly, check it and recheck it, and disconnect it and reconnect it... check fuses, cables... and both bulbs are ok. The only think I can remember that I can do is measure the power with a multimeter from the fuse until reach the bulb.
I found this [URL="http://www.dre.vanderbilt.edu/~aky/Bikes/Manuals/Service/FZ6/FZ6%20electrical.pdf[/URL] wiring diagram but, as far as I understand, the problems I'm trying to solve are the numbers 65 and 66 (front turn signals are working), but how should I measure?
I only know how to use a multimeter in a very basic way. I need the cable colors, where to find it... (Like you would explain to a kid what to do in a Whorehouse...(I hope you use this expression in English!))
Any other suggestions to solve the problem are very welcome and appreciated.
Thank you!
P.S. I remove the front fairing while studying the retrofit possibility.
Thank you!
![20150812_085622-1[1].jpg 20150812_085622-1[1].jpg](https://www.600riders.com/data/attachments/0/446-05b9d7885a30cf9b41ce701734b385de.jpg?hash=BbnXiFowz5)
