Renthal Bars, S2 Forks, S2 mid-pipe, S1 Oil pan, +++ OEM stuff ->LOOK!
Still have bars or brake lever? Got side swiped, low sided mine. Sad day!
Someone else has dibbs on the bars, i replied to them but haven't heard from them in a week.
In light of this post, I'll give them till the weekend and if i don't hear from them, the oem bars and levers could be yours. Let me know if that works for you.
Sorry about the mishap and hope you're OK!
Hi there, any idea if the S1 oil pan will fit the 2007 S2? If so I will glad take the oil pan!
I can tell you that an S1 header will not fit an S2 oil pan (without modding pan or header), but I think you **might be able to*** go the other way around. However, having not tried it, I would be hesitant to get your hopes up. It will bolt to the engine just fine. Its how the header collector fits that is the issue.
I bought it as backup plan in case the S1 header to the S2 chassis was a no go. I ended up grinding this bump off the S2 oil pan and welding up the hole and the S2 pan can be made to fit S2 CAT free header.
