I run the FZ pretty hard and am NOT the kind to lug it as its no good for any of us.
From the bikes stand point its doing more work which hurts MPGs (higher gears at low speeds) while allowing it to Rev freely has far more advantages than disadvantages.
- more oil flow cooling and lube
- more coolant flow
- higher vacuum = better mpg / up to point
- safer for getting out of harms way should there be need.
Monitoring engine vacuum as direct correlation to load or work being done gives a pretty good indication as to where the engine is happy. Not that our bikes have this but throwing a gauge on there or stepping into diagnostic mode where it can be observed is an option too.
A quick video from utube on vacuum, work, load, efficiency.
Driving with a vacuum guage for fuel efficiency - YouTube
And yes, while gathering info I hooked one up to Crisis!
Eric - have you ever given any thoughts towards a fuel controller and changing the map? Is the exhaust tip black on the FZ1?
