overtheede
Has anyone around 140 lbs installed a racetech spring kit?
If so can you tell me your spacer length. Just trying to save
some time.
Thanks
some time.
Thanks
Just did this install today with .90 kg/mm Racetech springs. I cut the spacers to 6.75" and with my 175 pound self (plus a bit for gear) and three washers per side (one under spacer and two on top, the kit includes 6 total...) my static sag is 33mm. Good enough for me. Took the bike for a ride and the difference from stock is significant. Less diving during braking and the bike feels more planted in turns. Also replaced the fork oil with 10wt. A worthwhile mod I would say.
I was using Racetech's definition of static sag. Sag
From forks fully extended to me sitting on the bike the forks compress 33mm. Sounds like that's your definition of rider sag. My static sag according to your definition is 27mm. Might need to add a bit of preload.
Well using racetechs worksheet my static sav is 36mm. What do you
Think tighting it up?
I'm doing that now. I ain't worried about it. Sag is a racing thing. I don't race so it doesn't matter to me. I ordered .95 RaceTech from BikeBandit. At 180 without gear I am supposed to need .87 springs. I got the .95's because they were on sale ($109.00)
I'm doing this because while I don't race I do like going fast. At more then 140, the bike wobbles a bit and tends to wallow and understeer when I change direction. Plus I bottom out when I use the brakes. SS lines and Organic pads means I'm not going to lose control but it is still a bit more excitement then an old geezer needs.
So when I took the front off (Doing stem bearings while I'm in there), I found that there were already after market springs in there. Probably Hyper Pro, since they are progressive springs and Hyper Pro sells about 80% of the after market progressive springs in America. RaceTech springs are linear, I don't think they even make progressive springs. The springs I have been riding on were in upside down, which might have been my problem. Anyway, I'm putting them back in, right side up and going with a 10 wgt fork OIL. I hope that works because this is a big job for an old man who still hasn't recovered from his last heart attack.
I'm waiting to see if BikeBandit will take the HyperTech springs back. The Service Manual gives a free length range of 347 to 354mm. The RaceTech springs are 318mm. Almost 10% shorter. That was too much for me. If they had been 340 or even 335 I might have gone with them. I'm sure if I was desperate and knew a lot about suspensions, I could have made them work. Instead I sent them back, or I'm trying to.
^^ agreed, throwing the springs in w/out setting the preload is not beneficial and you may not realize the full benefit of the right spring if not installed properly.
So, true: nothing to do w racing, but must be checked and set! You can throw a zip tie on the stanchion tube and you can have the values in 3 minutes! Now you know if you have the proper spring. Also, damping is what keeps the vehicle from bottoming out. A stiff spring w little damping and it just behaves like a Pogo stick.
As for running a non linear spring upside down it fatgues the spring much quicker and makes allot of extra friction in the process.
When in installed correctly, the softer section of the spring is flexing / compressing constantly over minor road variations. When upside down, the whole spring has to move up and down in the stanchion tube before the soft section compresses. This makes friction, wear, and heat. Granted none are astronomical, but over time it fatigues the spring. Not to mention the whole spring spring is moving in the tube is making contact and debris equals more contamination.
Yes, when installed properly there is still contact, but at least the whole spring is not moving constantly. Just the section being compressed. As a visual, think of droping the aluminum spacer in first and then the spring. Sort of the same concept - the fixed heavy rate section is now moving all the time and we don't want that!
Well after messing around with spacers I have my rider sag set
at 28.5mm. Sounds good to me. What do you guys think?
A few things:
The stock springs are dual rate, so it is highly probable you had stock springs in there. I am pretty sure Hyperpro springs would be branded...
Regarding the way they go in, it should not make any difference, the manual says to instal the springs with the small pitch facing down, but a LOT of people have them facing up from the factory when they open their forks. Either way, it makes no difference.
The Racetech spring length is meaningless, you just make up the difference with a new spacer, which is provided in the kit.
Lastly, sag really is not a racing thing, it is the most important setup you can do to your bike if you want it to handle properly! It really is worth doing...
Actually, not to start a fight but I have a service manual, for what it is worth. stock number is LIT-11616-FZ-61. In section, page 4-54 there is a NOTE: Install the spring with the smaller pitch facing up. Then there is a diagram so everybody understand what pitch refers to. On page 4-50, step 2 is measure the spring free length. That free length is 354mm (13.94 inches) to 347mm (13.66 inches).
I think you for your opinion but I believe I will follow the instructions from the people that built the bike and spend millions if not billions on R & D. How many hundreds of Engineers does Yamaha employee? Thousands?
Sag is important for an individual rider that is seeking to fine tune their performance envelope. The Factory just wants Owners to be safe.
I'll go with the factory. The spacers are for minor adjustments. I don't consider 10% to be minor. The Free Length range is 7mm. That would be what the Factory considers minor and to be adjusted for.
BTW, my Race Tech Springs were not branded.
I don't know what springs they are, as I wrote. My logic was that the factory DID NOT put themm in up side down. So logically, somebody else did. Why would somebody replace stock springs with stock springs? Springs don't wear out. Not on a properly designed motorcycle. The fork OIL was pretty new. Certainly not almost 10 years old like the bike is (it's an '05). So the fork had been worked on. I paid the shop 50$ per to do the forks. Seals, bushings, blow out the damper. I asked the Mechanic if it looked like it had been worked on. He said yes, so there was my second opinion. The most logical reason to work on forks is to change the springs, or do the damper valve. Anyone doing the valve would know enough to understand there are very sound engineering reasons why the pitch gets smaller at the top. Reasons based on the laws of physics.
You do understand that RaceTech sells springs. They don't make them;
IndustryNet
Not sure about Hyper Pro. They are European and might not be required to registar with the Government. Economics still applies. A Spring manufacturer Would make millions of springs with the economy of scale that provides. Of those millions, only a few thousand or even few hundred would be for motorcycles. The cost savings of buying raw materials for millions of springs would still be there as well as the lower unit cost of running the lines for an extra little bit to knock out the motorcycle springs after the SUV springs. So they knock out a few and send them to Sport Tech, which checks them. packages them, then ships them to you and I. Nothing wrong with that. It saves everybody money and creats jobs. A win-win.
Out of the Millions of motorcycles ridden worldwide today, how many had the sag set? 1,000, 2,000, Or about .0002 %
Why do you think that number is important? Maybe you are making money off it, in which case it is important. To you. Not to me and the many millions of riders who have no idea what sag is and ride along in safety without knowing or caring.:rockon:
