FZ6 footpegs don't fit - ideas?
motel6
portland
How much bigger is the bolt to the hole?
Sounds like you need to reduce the diameter of the bolt (sanding or lathe?) or increase the diameter of the hole (drill).
If possible I would work on the bolt.
Not much help, sorry.
Good Luck with it.
Cheers,
Mac.
Maybe i am stating the obvious, but these are the passenger footpegs, are you trying to fit them as passenger or rider footpegs? they are not exchangeable i think.
Good Luck with it.
Cheers,
Mac.
I ran to Lowe's and grabbed an 8mm bolt and a stop-nut. That will do for my ride with the girl tomorrow and then I will return them. They said they fit...they LIEEEE.
