New lube... DuPont™ Teflon® Non-Stick Dry-Film Lubricant
DuPont? Teflon® Non-Stick Dry-Film Lubricant
This unique dry-film lubricant leaves a long-lasting, micro-thin, pure DuPont™ Teflon® fluoropolymer coating that repels dirt, resists corrosion, and reduces friction and squeaks. It’s also excellent for high-temperature applications.
- Goes on wet to penetrate, then sets up with a clean, dry, white micro-thin coating
- Film bonds to most surfaces
- Lubricates parts to reduce sticking and squeaking
- Thin coating is excellent for tight tolerances and sliding tracks
- Helps materials resist chemical contaminants or water
- Acts as a protective coating for metal, plastic and rubber
- After solvent evaporates, the remaining lubricating film is non-flammable
- Effective from -100°F to 480°F (-73°C to 250°C)
Applications:
- Use on surfaces requiring a dry, non-oily, non-staining and silicone-free film
- Perfect for tight-tolerance applications where a microfilm lubricant is needed
- Woodworking and trade tools
- Chains, gears, cables, bearings, valves, shafts, tracks and slides
- Hinges, locks, fasteners, sliding surfaces, sealers, blades and bulb threads
- Electrical switches and connectors
- Mowers, garden equipment, snowblowers, gaskets, seals, rollers, plastic gears, sleeves, ropes, drive belts and bushings
- Outdoor power equipment, fishing, cycling, sailing and marine
- Cutting blades, drill bits, saws
- Gaskets, seals, rollers, plastic gears, sleeves, drive belts and bushings
- Can withstand temperatures up to 480°F (250°C).
