Negative captain....Long shot - garage door opener.
Negative captain.... X2servo gear?
"THM ###" is critical to salvation as it is the the answer!
What's left of the drive gear for a GM automatic transmission governor
:thumbup:I think he has it. Turbo-Hydramatic(THM) transmission family produced by GM. I am guessing the THM400 or THM375 leaning toward for 400 because it is a larger number.:thumbup:
OK, This is the only thing that came to quickly. If none of you are familiar with it I'll give you some hints. Good luck!:thumbup:
That looks like a hopper where plastic caps are vibrated up a channel and there may be other parts that attach for automatic assembly..![]()
Well then, that took all of 45 minutes. Yup you nailed it. Guess I'll have to try a bit harder next time.
I find it really interesting, the whole bowl vibrates. Well, sort of vibration. It shakes it clockwise quickly then counter clockwise slowly over and over till the plastic connectors climb out of the center and travel down the outside slowly being organized till they are all facing the same direction. This is then attached to an automated assembly machine. In this case it inserts pins and bends some of them to be used in all sorts of wiring harnesses and circuitry.
Sorry man! Lol! Unfair advantage. I've worked and built a few things.A ways back I worked in the machine shop at an injection molding plant. Besides injection and blow molds, we custom made a lot of our own manufacturing and assembly equipment.
I would tune the indexer assembly machinery when I came in, in the morning and when I left for the night shift.
I actually have a summer internship with a company who designs and builds the assembly and packaging portion and purchase the feeder bowl. They make tons of little connectors for just about every thing from cars to washing machines. Anyway, you're up.:thumbup:
Oh! You mean if I guess it I have to come up with something?![]()
