cj007
i have an 06 fz6 and my engine overheats if i let it idle for 5 minutes.. it has coolant and fresh yamalube full synthetic oil in it... what could be the problem?!
when you say overheating, can you explain how high the temp gage goes?
when im on the highway, the temp gage reads 2 bars on my 06, but when im at a stoplight, occasionally ive seen the temp gage go to 4 bars, and the outside temps arent even hot yet, then when i get going, the temp gage drops down.
i come from a vstrom which always read 2 bars, even if the outside temp was anywhere between 30 and 105 degrees.
is this much fluctuation normal on an fz6 ?
I get that too. During the summer months, if the bike sits at traffic lights for a while the temp goes to 4 stars and the fan is switched on. As soon as you get goinf the temp must drop again.
thanks for your help guys, i tore down the bike bled the coolant lines and added a little coolant to the radiator and it seems to be working fine... my temperature gauge would max out before and now it is steady 2 or 3 bars.. i appreciate your help!
