- Joined
- Oct 5, 2007
- Messages
- 4,894
- Reaction score
- 126
- Points
- 63
- Location
- Alkmaar Netherlands
Thanks for the reviews guys :thumbup:
I know I posted this in another thread a while back but I think it belongs better here:
It all depends on what your requirements are as to which GPS set up is good for you.
Here’s some info about GPS’s both from my own experience as from reliable sources:
Garmin:
I have a Garmin zumo 500 and I’m very happy with it, nowadays the Garmin 660 has replaced the 500 series. I use a separate small Bluetooth receiver which I keep in my inside pocket and an in-ear earphone (which I don’t generally use on motorways).
I love the track function, you can plot your route and look at it later in mapsource. This same function can be used to ride offroad (if that’s your thing) as it gives directions with an arrow.
The internal memory is not enough for all the europe maps but you can load seperate maps or expand it with a memory card (as I have done).
Another good thing about the memory card slot is that you can upload someone elses route (with a garmin) into the internal memory from their memory card.
The zumo cradle is great, easy to fit your GPS and it remains on my bike all year around. One small point I’ve seen by someone else is that if you have a permanent 12v on it (as opposed to switched on by the ignition/relay) is that this pin is more likely to corrode.
Although it can be used for playing MP3’s and viewing JPG’s I rarely use this, but it’s handy having the user manual in JPG’s especially when I started using it.
I find that the screen is good with little or no reflection.
A cheaper alternative is the zumo 220.
the main difference is size, internal memory (for routes and waypoints) and lack of permanent headset connection (but it does have bluetooth).
A big advantage of Garmin is that there are a lot of tried and tested routes available in Gdb format which you can find on the web, there are also some Gpx (universal) and ITN (tomtom) files out there but not half as many.
Garmin comes standard with mapsource a handy program to plan/view your route
Garmin can also be expanded by buying separate maps for walking, cycling and sailing (it’s well known for outdoor sports).
License: Garmin does both a “one time” as a “lifetime” update Garmin | United Kingdom | Maps - nuMaps
Tomtom:
My wife has a Tomtom for the car and it is almost perfect with getting you from A to B (in Holland at least), they spend a lot of time driving around checking their routing software. My zumo does make more mistakes in A-B routing but is easy to use for riding planned routes.
I read in several reviews that the cradle for the old tomtom rider II often broke so you quite often see this GPS being sold second hand without the cradle.
The urban rider.
I've read some good reviews about the new urban rider, and by all accounts another serious motorbike GPS and a good alternative to the zumo .
The basic urban rider with ram mount seems like a great deal but if you want the “cradle” (powered mount) and car kit you have to buy these seperate. You can of course charge it up before hand (which is said to be good for 5 hours riding).
The urban rider has no memory card, only an internal memory which means routes can only be loaded via a computer. It has an added feature "twisty roads" which can reroute you on the most twisty route, but it doesn't account for quality of road, so it could end up being a farm track.
The older Tomtom software/hardware had a maximum of 48 via points but the new urban rider doesn’t have this problem. The older tomtom riders had a problem with deviating from the planned route and this could only be solved with a lot of fiddling around in separate menus, although this hasn’t been directly solved the urban rider does allow you to pre program 2 buttons from the quickmenu, which can be used to easily navigate to the next via point (instead of the one you have already passed).
License: you have to pay yearly for Tomtom updates but they are cheaper than the garmin onetime
I used to use TYRE (made by a Dutch clergyman) to make routes for Tomtom, and this worked very well, I even sometimes view a gpx route (exported from mapsource) with it.
I think it depends on personal choice and budget which GPS is best for you.
Alternative set up:
I used to use a charged up palm top with Tomtom laid in my tank bag. It was a bit of a mess around as it had a separate GPS antenna and I had to be careful to keep it waterproof when it rained (which is almost as often in Holland as in UK). When it rained I could hardly see the screen.
Be careful when wiring up your GPS as some use less than 12v but have a voltage regulator in the adapter/cigarette plug to supply the correct voltage. This means if you directly wire to the 12v something will blow. On my old palm top I soldered the voltage regulator which I removed from a spare cigarette plug into an adapter box and connected this to a switched 12v source on the bike.
There are a couple of cheap solutions:
I hear good reviews over the [ame=http://www.amazon.co.uk/GIVI-S850-UNIVERSAL-WATERPROOF-HOLDER/dp/B002YEI2U0.]Givi GPS bag[/ame].
There are also similar solutions for Iphones
Be aware that Bluetooth uses more power so a charged up unit without a power source using this can run down the GPS's battery really quickly.
Don’t forget to shop around, I got my zumo cheaply via a French webshop, I only had to change language and load the extra maps I wanted (it was Europe maps but only France was preinstalled).
I connected my garmin cable to an unused plug under the LH cover it has four connectors of which 2 are a switched 12v supply.
You can also find more info here.
Garmin:
Tomtom:
The urban rider.
Alternative set up:
