- Joined
- Feb 7, 2009
- Messages
- 12,553
- Reaction score
- 1,205
- Points
- 113
- Location
- Cape Coral, Florida, USA
Shi . ! That don't sound good at all....
Stethescope time???
Stethescope time???
Ball bearings usually have play in them - With bearings it's about how smooth they turn. Any roughness at all or damage to the ball cages and out they go. I was just looking on a US website and the bearings are not that pricey... but then again, I'm not paying british taxes and suffering from the wettest year in history.
Apache Motorcycles Honda Yamaha Suzuki Kawasaki KTM CAN-AM Top Rated New & Used Motorcycle Dealer, ATVs, UTVs, Jet Skis, Scooters - serving Arizona. (I picked a 2005 model)
If you end up getting a 2nd hand set of gears, see if you can get the shift forks with them. Then at least you can compare the 2 sets of forks to see if they got a slight bend. The forks are not cheap to replace.
Will wait till wednesday
OK this might be a shot in the dark because it only happens in second, I've heard that noise coming from my car, it ended up being one of the throttle bodies. can you pinpoint where the noise is coming from?
Although i have noticed a hummmmm hummmmm hummmm hummmm hummmmm in ALL gears. Very very faint and not constant. Changes with speed and which ever gear i'm in. For example, if i'm in 3rd and go into 4th and stay at the same speed, the hummmm goes slower.
Right, i took the chain and sprocket off but you can't really hear it.
It needs a load through the gearbox to make the noise. Pre-loading 2nd gear doesn't make the noise go away either :-(
I'm trying to decide whether i spend £100 on 2nd hand gears or £300 on a 2nd hand engine
Tough question - The answer depends on how much storage room you have to keep a whole engine lying around - unless you e-bay the 2nd hand engine once the swap is done.
Do "the authorities" care about serial numbers etc? at MOT time.
Wonder what is wrong with the engine you are getting?
