AdamFZ
What a wonderful explanation, thanks.Nelly, the clutch disengages the engine from the transmission. The only time the transmission disengages input to output shaft is in neutral or that fraction of a second between shifts. Sometimes a shift will get stuck (the drum doesn't turn far enough to completely move the forks) in between gears causing a false neutral.
Our bikes are the same year and very similar mileage, Got a couple of questions?Those pictures are of all the gears that 2nd require.
FYI, the bike has done 27k miles so i expect this is normal wear and tear on the dogs.
I've got all genuine Yamaha parts ready to put it back together now.
Cheers, Good luck with the wedding.As far as I know, its the original clutch. I need to measure the thickness of the plates.
They are Storm hand guards, came with the bike.
I got a Yamaha touring screen.
No lol, that's some booze for my wedding !
Sent from my GT-I9300 using Tapatalk 2
Damn your fast!!
Very, very curious to see if the noise is gone as you did replace some parts, correct?
Better yet, how did you time the cams w/out taking the VC off? Unless you marked the chain and gear?? Hopefully throwing the block about didn't allow the chain off the cams.
I still vote the gear train is 100% but the shift mechanism is allowing something to contact. The tiniest amount of contact will make a huge noise. What is odd is straight cut gears don't walk like bevel cut helical gears as these change noise volume by the load imposed due to the angle cut.
